Putting car on jack stands
C280
I have a 1995 c280 and i wanted to put it on jack stands and didnt know where the jack stands would go in the front of the car. If i use a floor jack and use the rubber circle jack place to lift my car, where would i put the jack stands?
Is there another place in the front where i can safely place the floor jack so my car can get lifted?
Thanks in advance.
Thanks in advance.
C280
i know about that, thats where i put my jack stands, but where do i put my jack so I can raise the car. I have to raise it before i put the jack stands, if i put the jack on the rubber round thing i wont have a place to put my jack stands.
2004 C32 ///AMG
i have a question....
i need to place the rear (both sides) of my RWD car on jackstands.
how would i safely do this without the car rolling off?
(also need ther parking brake off so i can roll the fenders.)
But anyway, just lift it from under the ball joint at the bottom of the spindle. You'll be fine.
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
Getting a jack under the LCA spindle would be tricky with a tire in place and you'll have to deal with the movement of the suspension. Better to use the opposite end of the LCA, where it attaches to the chassis. That particular mounting point is reinforced and highly unlikely to be stressed by being used as a jack point.
1993 190E 2.6
Is there a pumpkin on a benz? Big round thing in the middle of the rear axle. When we put a lift on my friends jeep we just lifted it there. It only takes one jack because it lifts the whole rear. wont rock back and forth because of the front tires. Put brick/cinder block/ something to stop the front tires from rolling forward or back. Do it on a flat service.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
2014 ML350 4Matic
At the front place a 2 x 4 on the jack pad and place the jack under the front crossmember (it is just aft of the plastic tray). At the rear place the jack under the differential.
1 Post
