ABS,ASR,BAS warning lights on.
Got home last friday everything ok, parked up, went to start the car on monday and the ABS warning lights stayed on. ABS not working, I have changed the brake light switch as I gather this can cause this problem, but it doesn't seem to be the cause here. Has anyone any other Ideas before I trot along to the dealer?
Thanks, Timbo. 98 C230K Sport
Are you sure your battery is good/not going bad? As the battery gets weak, the car computer shuts off functions like the ABS when there is a chance that the battery may not have enough power to make them work in an emergency situation. You can find many posts about the ABS light going out when a new battery is installed.
Take it to an auto parts store for a free battery load check.
Doug
Doug
It's not the battery, it's a little over a year old, anyway, when the battery went dead before replacing it ABS etc continued working fine. I have also tried the lock to lock thing, still no good.
Timbo
Timbo
