Wet on passenger side floor
Old Jan 20, 2007 | 03:58 PM
nasa's Avatar
Hi there,
just bought MB c200 (1998) last year and I had this problem with the passenger side front floor getting wet. It just happen recently after I sent the car for automatic washing and its happen again when it is raining but I could find any leak..please help
Old Jan 21, 2007 | 10:22 AM
Whatstheprtnmbr's Avatar
1998 C 230
Check door seal and firewall area
If the seal around the passenger door is deteriorated, split, or has cracking it may be causing this mysterious leaking problem.
I would also check the passenger side engine compartment area (fire wall)where there may be a cabin air duct leak on that side, this is usually located under the glove box, check to see if there is any unusual moisture there also.
Old Jan 21, 2007 | 06:07 PM
KILLERHERTZ's Avatar
2013 SL63 AMG
Open up the engine bay, have a look down the top right hand side in the gap by the hinge. Remove all the leafs etc that you can see.
Basically all the leaves etc have blocked the drainage holes and water is seaping throught the cabling gromit into your car.
Its a common problem.
