external light out indicator
Old Feb 16, 2007 | 07:24 PM
kgard's Avatar
I have a 1998 Mercedes C280 and the external bulb out indicator started coming on a couple of days ago. I've checked all of my external lights (even the tag lights) and don't see any that are in need of replacement. Is there something that I'm failing to check other than what can be seen by turning the lights on and checking the signal lights, brake lights and backup lights. I've also checked the high beams and they are working properly as well.
Old Feb 16, 2007 | 09:43 PM
Whatstheprtnmbr's Avatar
1998 C 230
Depress brake pedal
The brake light has 2 filaments, have a helper check to see if they light up when depressing your brake.
If you have a third brake light (center) this may be the cause also.
Old Mar 13, 2007 | 12:21 AM
dafowler88's Avatar
1995 Mercedes-Benz C280 W202
Yes, and the switch that turns on your lights. When you turn it, pull it out also. Until it clicks twice. That means all the front lights are on and the other rear lights are illuminated. Have someone watch the rear of the car when the second click occurs.
Old Mar 31, 2007 | 04:07 PM
MBTECH2003's Avatar
2000 ML 320, 2003 CBR600F4i, 99 Eclipse GSX
Non Mercedes bulbs will light that light in the cluster, due to improper resistance.
Old Apr 1, 2007 | 12:11 PM
JOESID's Avatar
Its also pretty simple technology, the light only comes on when the bulb is actually out. You could have a bulb with a bad filament that turns on and off when it pleases....
Is the dash light always on? or was on last week?
