Another Transmission Question...
Car has 64k miles
Questions are:
1. Can bad motor mounts make a tranny not perform as it should, and would it feel like slipping? My car shakes a little when shut off, like the mounts could be bad.
2. If I am low on fluid (just serviced 10k miles ago) where would it be going? I have zero leaks on my garage floor and there is no tranny fluid in my coolant (thinking from the cooler it might mix).
3. The dealer replaced the connector on the tranny with the updated version... could it be leaking on to the computer and causing this behavior? If so, is it enclosed so I would see no leaks outside the car?
I hope someone can help me... I am afraid its the tranny going... but the tranny is strong...
- Get in and shut the door
- Turn key to position II (DO NOT START THE CAR!!)
- Press the accelerator pedal to the floor till you have pressed the kick-down switch and hold for 15 seconds.
- Turn key to 0 and leave it in the ignition
- Release accelerator pedal
- Don't touch any buttons or open the door for at least 2 minutes
- After 2 minutes start the car and drive as normal for at least 40 shifts of the transmission.
