My 1995 C280 shakes
2002 C240
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hi,
Couple of weeks ago my car (has 101k miles) started to shake at a light. I turned off and restarted and the vibration was gone.
Today it happened again. It started to shake also when stopped and when driving. It shakes stronger when stopped and in D or R. In Parking and Neutral it shakes slower. Also the RPM in Parking is around 7-800 and in D and R is 500-550. I drove 2 or 3 miles and the shaking was still persisting.
I had the idea to disconnect the battery. After that the engine was running fine. The shaking disappeared.
I read almost all topics regarding SHAKING on this forum and i haven't found an electronic cause so far. Could it be because of the Central Unit? Maybe a sensor is sending wrong data and the ECU recalculates all parameters.
I don't think it's a mechanical problem because the problem persisted until I disconnected the battery.
What do you think?
What do you think?
'00 E320 Estate (W210)
Hey there.
Check your engine mount if you've never replaced it. My old '94 C280 had the shakes in D and R at around 140k, and turned out the engine mount needed replacing. After that, it was all good!
Then my gearbox started to give me awkward shifts, so I traded her in for 2000 C240![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Get your mechanic to check out the engine mount
