Criuise Control doesnt work
Old Nov 13, 2007 | 03:18 PM
proroad's Avatar
98 Mercedes c230
Hello, I searched the forum and couldnt find much on this.
My 98 c230 cruise control does not work. It did when I first got the car a few years ago, now does not engage at all.
What are the first things to check out? Fuses, wires? ect.
Thanks,
Brian
Old Nov 13, 2007 | 04:06 PM
99MBSport's Avatar
1999 C280 Sport
The cruise control works off the brake light switch, are there other lights on the dash area like the BAS/ASR light?? if so change the brake light switch at the top of the pedal. They are noted to be crapola.
Old Nov 14, 2007 | 12:45 PM
proroad's Avatar
98 Mercedes c230
thanks for the reply, where is that brake light switch? I looked in side on the brake pedal but there is housing there. Is that where you mean?
Brian
Old Nov 15, 2007 | 05:25 AM
99MBSport's Avatar
1999 C280 Sport
The brake light switch is on the steering column under the knee pad. There are 4 phillips screws attaching the panel and it slides out nd down. Look up on the steeringn shaft and you'll see the light switch. 1/4 turn and a small press in and it should pop out. Ther are pictures on the board somewhere if you look up ASR/BAS light.
Old Dec 24, 2007 | 05:48 AM
noShame's Avatar
Also, if there is a different dimension in the front and rear (if you have changed the tires/rims) it wont be working as expected or at all.
