Fuel Gauge problem
Old Jan 26, 2008 | 03:40 PM
vijay101's Avatar
2000 C230K
Fuel Gauge problem
I recently purchased a 2000 C230k, my fuel guage tends to act weirdly. I gas up the car and the needle doesn't go up, sometimes when i start the car its full and then if i restart after awhile its empty. Can someone explain me what the problem is and if it is an expensive fix
Thank You
Vijay
vijay101 is online now Report Post Edit/Delete Message
Old Jan 26, 2008 | 03:52 PM
timmyj51's Avatar
Most likely its a bad fuel gauge sending unit. BUT, with my '95 C220
I learned MB put out a TSB warning owners that a faulty fuel
gauge is often caused by a pinch/break in the sending unit wire at the
point where it threads under the back seat. Don't know if the TSB would
apply to your year/model.
Old Jan 27, 2008 | 05:42 PM
ScottyP's Avatar
95 C280
Or maybe your gauge needles are simply sticking..
You can clean them with a little alcohol on a q-tip and see if that resolves it.
I found a permanent fix to the sticking gauges problem. MB actually makes covers for the cluster post. It resolves the needle sticking problem but is only sold in Europe. I have some sets if interested: https://mbworld.org/forums/classifieds/226718-sticking-cluster-gauge-needles-fix.html
Scotty
Old Jan 27, 2008 | 11:55 PM
vijay101's Avatar
2000 C230K
I found a permanent fix to the sticking gauges problem. MB actually makes covers for the cluster post. It resolves the needle sticking problem but is only sold in Europe. I have some sets if interested: https://mbworld.org/forums/showthread.php?t=226718
Scotty
i dont think it is stuck, because out of knowhere it will start working, somedays it works and then somedays it doesnt. im pretty sure its a sensor. but thanks anyways
Old Jan 29, 2008 | 11:38 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Thank You
Vijay
it could be your fuel sending unit, if the car has warranty take it back check for lose wires
