Center and Side Blowers
Old May 14, 2008 | 06:48 AM
w202mad's Avatar
w202
Hi Guys,
This is my first post, hope you can help:
The center blowers and side blowers have very little air coming out of them, even on MAX, they make a lot of noise but nothing much coming out. I drive a 2000 W202 C180.
Has anybody come across this before, this is my first merc, is it normal?
Cheers
Old May 15, 2008 | 05:19 AM
rfoo's Avatar
1994 C220
Originally Posted by w202mad
Hi Guys,
Cheers
Try to check your cabin filter or microfilter. you might need to change it. I bet it's jammed by heavy dust. It's located just below the passenger side dashboard.
Old May 15, 2008 | 06:07 PM
xvvvz's Avatar
C230K
If rfoo's suggestion doesn't help and you know the blower is still blowing strong (no bad brushes), you may need to check to see if the duct flaps are operating correctly. These are controlled pnuematically and are starting to be a problem as these cars age and the plastic gets brittle/splits. $$ repair.
Old May 16, 2008 | 08:33 AM
w202mad's Avatar
w202
Cheers guys, I'll check them out and I'll let you know how I get on.
Old May 30, 2008 | 02:29 PM
Flyingbanana's Avatar
1997 C280
A couple of things
It may be a couple of issues.
There may be nothing wrong. If the climate control is on auto, it does not blow from the front vents unlike jap cars. Took me a while to get used to. Someone told me it's german engineering and they don't want to blow air in your face
The other common problem is if you vent flaps are not working due to the failure in the vacuum system that operates the flap. No matter what position u put the blower setting in, it only blows air out of the defroster vent. There are alot of threads on how to detect this. go to club202.com.
Hope this helps
