shaky start: fuel filter replacement?
Old Jun 1, 2008 | 09:57 AM
bimmer5's Avatar
C230 kompressor 1999 (W202)
I have a '99 C230 Kompressor (W202), 100K on it, and as of recent I noticed a change when the car starts on cold. For a 2-3 seconds it feels like it starts on 2 cylinders, looks like it won't make it but it starts. I haven't notice any problems while driving.
I googled around and some suggested replacing the fuel filter. I would like to replace it by myself. Need to know the exact location, tools needed, etc. Any suggestions would be highly appreciated.
Thank you.
Old Jun 11, 2008 | 05:01 PM
bagge's Avatar
w202 C180
tried just changing the sparkplugs?
Old Jun 11, 2008 | 05:39 PM
bimmer5's Avatar
I haven't tried anything yet. You are right, it could be the sparks, too. I think if I do the scheduled 100K maintenance it should resolve the issue. Someone suggested using a lower-octane gas; I did it and I think I haven't noticed shaking since then.
Thank you for your reply.
Old Jun 11, 2008 | 09:47 PM
xvvvz's Avatar
C230K
Search the archives in the w202 forum at Benzworld.org. There are a couple of thread with pictures.
Old Jun 23, 2008 | 11:41 AM
gauthier613's Avatar
C230 Kompressor
http://benzguide.com/index.php?title...er_Replacement
Remove the Plastic Cover
Remove the Bolts holding the Support Braket in place
If the plate is rusted you can Buy a new one about 37$ CAD from the dealer.
Disconnect Feeds and plug them up to avoid leaking.
Insert new Filter Reconnect Feed lines Mercedes used oktik Fitings. Do not use a standard clamp. Fuel Clamps are ok but #oktik Fitings take the most pressure.
Retighting Braket and Plastic Plate
Old Jun 23, 2008 | 11:46 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Its probably new battery time also !
Old Jun 23, 2008 | 11:50 AM
C230 Kompressor
Try some of these too
Check the compression of each Cylinder Easy Job
Batter Test
Dirty Intercooler, MAF and Intake
Clogged Filter Fuel and Air
Dirty Dump Valve from Supercharger (Kompressor)
Check the OHM resitance of your spark plug wires.
Check for OBD Codes
www.BenzGuide.com
Old Jun 24, 2008 | 02:35 PM
JUAN CASAUS's Avatar
2005 E55 AMG
how do you check the dump valve for the kompressor models? mine is doing the same thing abd the codes say it's the cam position sensor. any info?
