Looking for best headlight kit and housing for 96 C220
MB C220 1996
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hello all,
I am having an issue with my current headlights. I had them replaced with aftermarket headlights and a hid kit added to them. since I had the body shop install them, they totally jacked them up to where I can not adjust the lights up or down because the bulbs didn’t fit and they cut a whole to make the space larger
. They did all this while I was away on business, and when I returned, everything looked ok until it was night and I can’t see jack. So now, I am stuck with lights that are not aimed correctly, and all that I can use is my high beams, which I have aimed low so I can see when I drive at night.
Does anyone have a suggestion on should I go back with the stock version of the headlights and try with hids, but then the housing might melt and the bulb wont fit.
Should I buy replacement headlights? Nevertheless, from where and a pair that can stand up to hids and actually fit the bulbs.
What size bulbs should I buy to replace the ones I already have?
Can some one out there please help?
Hassan
Hassan
1994 C220
Hello all,
Hassan
Hassan
What kind of aftermarket did you install?
