help plz asap
Benz 280
help plz asap
So istarted driving and I see this light turns on. Next to check engine light. Its a circle and like 3 things on the side. What does this mean? I have 95 c280. Thanks
1994 C220
It's the brake sensor telling you that yor front brake pads are worn out. Just change the pads and the sensor and it'll be back to normal. The sensor is by the way, separated when buying the pads, i bought 4 pads and 2 sensors. according to the shop i brought it to, the sensor can't be re-used.
c230 kompressor 1999
my dealer recommended the ngk but my friend has a 98 c230 and he use bosch platinum +4 im not an expert on spark lugs but i think they are similar, not that much difference
1994 C220
I use Bosch Platinum for my car and there's not much difference for the NGK spark plugs. I use to used NGK back when I had my 124 wagon. I never really had problems between the brands. It both work ok except that I got the NGK cheaper than a bosch.
C280 NGK7090 single side electrode plug platinum oe style.MB engines hate multi tip plugs,they cause problems and the 7090 plugs are only $2.89 at most auto parts stores.Why mess with what works?
Torque em right,use no anti seize.Done
brake pads and sensors www.autohausaz.com
