c280 engine knock on start up
Old Nov 6, 2008 | 12:36 AM
JACKC141FE's Avatar
99 C280
Hi all I need some help, on my c280 103k miles, when its cold the engine knocks for a few seconds when started. Can the oil be draining down from the oil filter causing a zero oil pressure dry start? Is there a oil drain back valve in the system that may have failed?
Thanks Jack
Old Nov 6, 2008 | 03:31 AM
Untertürkheim's Avatar
You mean lifter noise?
What kind of oil and filter are you using?
Old Nov 6, 2008 | 08:41 AM
vinceC's Avatar
2014 ML350 4Matic
My 2000 with 126K has done this since I bought it with 60K. Since it was under an M-B extended warranty I had the dealer check it out several times. When I finally was able to talk to the Shop Foremen he told me it is carbon buildup on the top of the pistons. The M112 V-6 has very small clearances and is somewhat prone to this problem. He recommeded adding a cleaner like Techron every 5K or so. It seems to help on mine - the knocking is considerable reduced.
Old Nov 7, 2008 | 12:37 AM
JACKC141FE's Avatar
99 C280
Oil
Using Mobil 1 Syn 10/30 and the standard MB that goes in the top of the v6 engine
Old Nov 7, 2008 | 12:41 AM
JACKC141FE's Avatar
99 C280
Thanks i will give it a try.
Old Nov 7, 2008 | 05:47 AM
That is the wrong oil, it is not MB approved. It, along with carbon buildup can cause the valve noise.
Old Nov 7, 2008 | 08:00 AM
vinceC's Avatar
2014 ML350 4Matic
I don't think the OP is talking about valve noise. The noise I have experienced, and I believe the OP is describing is a distinct knock - it sounds more like piston slap or even a rod knock.
Mobil 1 0-40 or 5W-40 is the currect spec for this engine.
Old Nov 7, 2008 | 06:43 PM
Not mobil 1 5w-40.
Old Nov 7, 2008 | 06:45 PM
There is some good information here: https://mbworld.org/forums/showthread.php?p=3156412
Old Nov 7, 2008 | 08:42 PM
xvvvz's Avatar
C230K
From what I have read, it could also be a pulley bearing going bad or a tensioner going bad. I am dealing with a quick bit of knocking sound at startup and have read about many different causes, so it may not be a simple diagnosis. You need to experiment more and give us a more detailed description.
Old Nov 7, 2008 | 09:26 PM
vinceC's Avatar
2014 ML350 4Matic
An MBUSA update issued to dealers on June 5, 2006 instructs dealers to draw down their stocks of 0W-40 in preparation for a change to ESP Formula 5W-40. In the FAQ section the bulletin states that the new specification MB 229.51 is a universal oil that can be used in both diesel and gasoline engines. It goes on the state that while the 5W-40 is under study for AMG models, the dealers should continue to use 0W-40 in those models. It goes on the state the 0W-40 will not meet MB 229.51 specs. It also states that 5W-40 is backwards compatible with 0W-40.
The only place I can find ESP 5W-40 is the dealer. I still use 0W-40, but it is getting hard to find locally, and not due to the hurricane driven shortage. It just doesn't sell well locally so all the stores have reduced stock and I have to order it. My dealer price on ESP 5W-40 is competitive so I will probably have to switch soon for convenience sake.
Old Nov 8, 2008 | 12:23 AM
It is better to avoid low SAPS oils unless required by your car. the -1 spec oils are not a further generation, so it is not a question of backward-compatability. Stick with 229.5, it is far better for the engine.
Old Nov 18, 2008 | 05:59 PM
vinceC's Avatar
2014 ML350 4Matic
Interesting note: The September 2006 issue of Factory Service Products listed 229.51 oils for both gas and diesel cars. The 2007 issue contains a notation that 229.51 oils are for diesels only.
So I stand corrected.
I have attached the latest issue for your information.
Old Nov 18, 2008 | 11:31 PM
How do you come about those PDFs? I would like to see the latest release, I would imagine there have been updates since 2007.
Old Nov 19, 2008 | 07:54 AM
vinceC's Avatar
2014 ML350 4Matic
Untertürkheim
The August 2007 issue is the latest release. I get them from the Startekinfo website. It is part of the free information available on the site. I have attached a screen shot showing where it is located on the site.
File Type: pdf
Old Nov 19, 2008 | 08:26 AM
Untertürkheim
Many thanks! Great information.
