Wiper Wash
Old Jan 9, 2003 | 09:39 AM
flyguy's Avatar
C200K
Wiper Wash
My wiper wash is out of service.....is there a DIY way to change the motor? Check everything,water level,tubing....all inplace but don't seem to be able to squirt. Can anyone help? Thanks.
Old Jan 9, 2003 | 11:50 AM
MBKid's Avatar
96 Mercedes C36
Not sure if that would be a problem with the pump but if it is the pump is attached to the platic washer fluid reservoir. It looks like a cylinder and can be pulled off.
Old Jan 9, 2003 | 12:37 PM
DougandhisC280's Avatar
2008 SLK-280
Before you go and change the motor, pull a tube off and see if it squirts out of it. Sometimes the nozzles just get clogged with wax and stuff.
Old Jan 10, 2003 | 03:36 AM
flyguy's Avatar
C200K
Thanks MBkid and Doug,will go check on those later. Hopefully it's a simple choke on the tubing only!!
