C220 Crank Position Sensor bolt type?
2003 E55, 2005 ML350, 1995 C220, 1996 C220, 1997 BMW 528i, 2003 SL55, 2000 Honda CRV, 2010 Honda CRV
I'm attempting to remove the bolt holding the CPS to the engine. As obviously difficult to replace from above, I can access by feel the location from underneath the car on the driver side. What is the bolt type? I assume it's a Torx type (T-30 bit seems to fit), but I'm wondering if it could be a 5mm Allen? Does anyone know? Reading the CPS removal on other MB models, a thread mentioned a Torx socket E8, but I know the W202 '95 C220 I have isn't that. It needs a bit of some sort.
Thanks! I did call my stealership today to get an idea what that bolt is and according to the guy, it's a M6-14 bolt! They didn't have one in stock, wanted $2+ for one, so I got on from like Ace Hardware. He told me to check them out. Sure enough I got a M6-12 and a M6-16 because there isn't a 14mm length bolt out there that I can find. Anyways, that Torx T-30 size is the size of a 5mm Allen wrench from looking at the M6 bolt. Now I'll try to remove it if I can and keep you guys posted. Yeah, on my '95 C220, it isn't an E8 Torx socket...unfortunately!
Removed Bolt; Hard to remove sensor
Well, updating my progress here, I was able to remove the bolt!! It is a T-30 Torx bolt, unlike what the stealership told me that it's a M6 bolt. I found the metal of this bolt to be pretty mild. I pretty much ruined it with my Torx bit trying to take it off from underneath the car. Per other posting tips, I was able to access the bolt from the top using a longer extension. Now with some hope, I'm having a hard time removing the sensor! It's buried between the transmission housing and a bracket for the intake manifold I think. I don't even think I have the clearance to pull it out if I can. Any advice on past CPS replacement experiences???
