Right brake light keeps going out
Old Feb 10, 2009 | 05:38 PM
rondocap's Avatar
Mercedes S55 AMG
Everytime I drive for a few days, the rear right brake light always stops working. I just open the compartment up, and push it around a bit and it starts working again.
Is it just getting loose? Is there a way I can keep this from happeneing? Maybe there is rust there? Anyone else have this problem?
Old Feb 11, 2009 | 03:47 AM
rfoo's Avatar
1994 C220
This is a common problem to all w202. Normally the bulb socket really goes bad and tends to become loose and so as the bulb contact. You can either replace the whole socket thing which doesn't really cost much or you can have it glued properly so it won't loose.
Old Feb 11, 2009 | 02:05 PM
skyking1981's Avatar
1994 c280
how to fix socket
on my 94 c280 the metal socket was not properly "welded" into the plastic. The little pegs were not holding the metal in place. I squeezed the metal to the plastic and melted the little pegs down with a soldering iron...actually I think I used a screwdriver and a cigarette lighter. Works perfect now!
Old Feb 16, 2009 | 11:19 PM
JoNRoksIT's Avatar
'99 C280
i had the same problem and just had to bend the metal peice up to touch the socket of the bulb a little better...
Old Feb 17, 2009 | 08:26 AM
w202305's Avatar
c230 kompressor 1999
i did the same thing with my
Old Feb 18, 2009 | 06:14 PM
jnolte's Avatar
744 C36 AMG,040 C43 AMG, CLK55 208, CLS55 IWC, CLK500 Rocketbunny widebody
same here !
