Help Brake Light, ABS Light, Pad Light on!!!
I had an ABS issue last may, and after taking the multi plug off the ABS pump, and cleaning the contacts, I never seen it again - until now,
The car has been laid up since the end of january (Outside) and the battery has ran flat a couple of times. I retaxed it the beginning of this month, and since ive started using it, the light has been coming on intermittently - but ive not charged the battery properly, only jump started it when its dead.
Also my heater is only blowing warm air out of the passenger side (unless I rev it really hard)
Hoping a good charge/run will sort these issues out as i've got an MOT soon, and it wont pass if the ABS light is stuck on!
Ben
