c280 power windows problem.......
one time when it was really cold outside, my windows wouldnt roll all the way down, they froze mid way.
couldnt roll them down or up. I fixed it tho by taping up/up/up/up on the window control and it eventually rolled back up, slowly but surely.
when it was warmer the next day my windows worked like normal. havent had a problem with it since.
if you are getting 0 power to your windows, perhaps the motor dead? might want to have a mechanic see whats wrong. dont take it to dealer or they charge you 90 bucks just to look at it.
i just check now the forum,
is now dark ,tomorrow i will tray the tips that doug....sc280
give me ,i will keep you posted.
by the way all my windows do not work!!!!!!!!!!!!!!!!!
keep on touch.
Hook me up, man! My front Driver's side window hasn't gone down in a while! When I try to bring it down the lights do dim, so what's the crazy fix? I can hear the fuse in the trunk when I try bring it UP even though it's already up. It sounds as if it would go up if it was down... but it won't go down at all. Make sense??
Matt
i tray your tips and when a push the switch for sending the window down ,the interior ligth is steady, this mean the switch is bad ?
note that i tray with all the switches and none is working,plus even my sliding pop up roof is not working.
any other tricks ????????????????
thanx alex.
Matt: This is for you buddy. First you have to take off the door panel to get to the motor. To do this, unscrew your door lock pin, unscrew the screw 10 inches below the door lock pin. There is one under the speaker and one more on the bottom of the inner door handle. I think that's it. Once you have the door panel off find the motor. It's the goldish, silver thing. Have someone hold down on the window swith in the direction you're trying to get the window to go down. Get a hammer. Beat the crap out of the motor until the window goes down. I swear this works. The motor corodes on the inside and you have to beat it loose. What have you got to lose? Believe it or not, the dealer showed me this. Good luck and happy whacking!
Matt
Any suggestions? I have tried the window resetting thing and didn't work, specially that the door has to be open while doing it too. I have also changed the fuse, unplug the battery, etc.. and didn't help.
Any ideas?
