Replacing windshield wiper motor
Initially, my wiper was occasionally sticking. At the time I was thinking that maybe the type of wiper that I bought from auto zone wasn't compatible or that maybe the windshield glass treatment that I was using was causing the rubber of the wiper not to slide as it normally would. Eventually the problem got worse and would completely stall. My wiper motor would continue to make noise as it attempted to force the wiper down and would eventually shut itself off. I would later have to get out of my car and reengage my wiper switch to the on and then off mode as I guided the blade back to its starting point so that it was no longer frozen in the middle of my windshield. At this point I decided that it was time to take a deeper look at what was going on with my wiper system. After reading about a million different forum posts I was able to find and create a very good path of diagnosing and fixing the problem.
***I will reference the following two links throughout. Don't worry about viewing yet. Just follow my path.
link A- http://202tech.mkosonen.com/howto/wiper.html
link B- http://members.lycos.nl/mbenz/windshield_wiper.htm
(link B actually explains another procedure but it has great pictures and directions of removing the MB wiper system as well as how to put it all back together so that it works)
First, I just want to familiarize everyone with the main parts that make up the MB wiper system. There are five main parts to the MB single wiper system.
1) First we start with the wiper arm, commonly called the windshield wiper, that everyone is familiar with.
2) Second, we move down to the mechanism that holds the wiper arm, which is technically called the Windshield Wiper Transmission but referred to as the wiper mechanism throughout the links. Strangely however, link B refers to the entire wiper system as the wiper mechanism and then later calls just the transmission the wiper system.....so keep in mind when reading (Viewable at the bottom center of your windshield and about the size of a small football.)
3) Next, we move down to the wiper linkage, which is referred to as the offset plate in link B. The wiper linkage or "offset plate" simply connects the wiper motor (#4 below) to the wiper transmission (take note, you cannot yet see this item without removal of the entire wiper system).
4) Then, we have the wiper motor, as mentioned above. The wiper motor drives the wiper linkage or "offset plate", which activates the wiper transmission, which moves the winshield wiper back and forth in order to remove snow or rain
5) Finally, we have the mounting bracket that holds the above parts 2, 3, and 4 all together and to your car.
Start here
1. It is very possible that the solution to your problem is just a quick five minute lube job of the wiper transmission. Take a look at link A for great directions and pictures of how to do this. If this is your problem then you are done.
If not....as was my case continue ahead
2. Your next problem could also have a fairly quick solution. Part # 3 above, the wiper linkage or "offset plate" connects to the wiper transmission and wiper motor by a pressed fit, secured by a nut. It is a very common occurrence that the nuts that hold the wiper linkage to the wiper motor and transmission eventually loosen and cause the linkage to slip out of correct positioning. If this happens it will cause your wiper blade to hesitate or stall because the linkage or "offset plate" has to be connected to the motor and transmission very tightly and in a marginally specific timing or position in reference to the motor and to the transmission. Take a look at link B to get an idea of how to remove the wiper system and reset the positioning of the linkage or "offset plate" in reference to the wiper transmission or "wiper mechanism" and wiper motor. But first before you do so you are going to want to pull the wiper transmission off of the wiper mounting bracket and inspect and lube the graphite gear found on the opposite side of what you lubed up in step #1. It is rare for this gear to be chewed up but if it is then you will be replacing the wiper transmission, which I have heard can cost around $ 700.00 for the OEM part
and still possibly the linkage and motor***Back to reseting and retighting the linkage "offset plate". remember that the surface of the linkage is a beveled pressed fit, so as long as the surfaces of the linkage aren't too chewed up you should be able to drive that nut on hard enough to achieve the necessary pressed fit. However, if the linkage is too chewed up from slipping for too long, you may have to buy a new linkage. The best deal that I found on this part was at http://https://www.autopartsway.com/secure/cart.cfm I think it was appx. $ 45.00 or $ 50.00
If you solved your problem here then great!! Many actually do. However, this was not the case for me. I waited too long to take these steps and eventually burned up the gears in my wiper motor. With what I know now this is how my problem slowly progressed. Initially my linkage slipped just a bit here and there so my wiper blade was hesitating occasionally until it slipped just enough to fully stall the wiper motor due to improper timing or configuration of the linkage in respect to the motor and transmission. The continual stalling of the motor leads to the gears inside of the motor burning up.... specifically the plastic or composite gear. This is typically how these wiper motors go bad. One of the gears inside is made out of a plastic looking material and it just gets chewed up when too heavy of a load is continually applied to the wiper system ie,. turning the wipers on before clearing the windshield of a nights worth of snowfall.
And of course this leads to the slipping of the linkage as explained above. 3) If you are to this point then you are also replacing your motor. Ok, there is good news here however
. The good news is that a generic wiper motor can be found online for a fraction of the cost. I used one made by Vemo, which actually works very well! This item costed me $ 95.00 compared to $ 300.00 plus for OEM. I purched that part from http://www.autopartswarehouse.com and the shipping was free. The other good news is that these motors can eventually wear out just from normal use. Thus by replacing it now you save yourself the headache later.
