W202 idle on crusing
Old May 19, 2009 | 06:16 PM
KompressorGpl's Avatar
Hello! My W202 as developed a strange thing: let's say i'm driving on 4 gear (manual) and put on N the idle gets to 1000 rpms and then runs up to 1550 and stay there till i put a gear or after ~2 minutes of idle...
Old May 24, 2009 | 03:59 AM
Hello! another thing: yesterday i disconnect the baterry for 30 minutes. Go for a drive and the car run run normally. Today put it to work and the problem came back!!!
Old Jun 22, 2009 | 04:53 PM
Hello! I went to a dealer and came with a lambda sensor problem. Buy a Bosch unit anda the problem is still there!!!
Old Jun 22, 2009 | 06:34 PM
SZMB's Avatar
2004 E500 CLK320
I don't think the lambda or O2 sensor would affect the idling speed. Maybe you should check or clean the MAF sensor or the idle control valve. Just thinking out loud...
Old Jun 23, 2009 | 10:56 AM
Thanks! And do I do it?
Old Jun 25, 2009 | 03:53 AM
Hello! I did a little experience: change the MAF. The idle problem is solved! But NOW i have a new problem: when the car is in N and do a hard accelaration the engine look like a boxer one. If i do a gentel accelaration the engine revs normally...
PS: I miss my JAP'S...
Old Jun 25, 2009 | 03:05 PM
SZMB's Avatar
2004 E500 CLK320
You may want to take out the throttle body and clean the paddle with carburetor clean. Sometimes the paddle gets sticky due to oil or gunk depsit.
Old Jun 26, 2009 | 03:36 AM
Thank's, but i did it 3 or 4 times now...Still the same...
Old Jun 29, 2009 | 05:03 PM
News: i went to a Bosch dealer and came out with 6 erros. The guy didnt new that my car is running on LPG. At first he said that i had a leak on the intake manifold or anything related... Then i said that the car is running on LPG he said that i had a problem with the spark plugs. Recomend to change to a set of Bosch LPG...
Old Jul 2, 2009 | 09:51 AM
Hello! As my car is running on LPG i went to the guy that install the sytem. Explain the problem of the car and he connect the laptop to the car. Go for a drive a the result was a very poor calibration on the injeccion (40% less than normal). Run the car for aroud 100 km abd so far is normall (idle inc.)
Old Jul 7, 2009 | 09:25 AM
Thank´s to ME i found the problem: NEW MAF!!!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
