1999 C230 Kompressor, central locking mechanism stuck!
Christian
Chris
Normally motor only runs when more vacuum that motor supplies is required, if theres a leak it runs full time to maintain vacuum level.
put your head inside the trunk and hit your unlock button on your remote(or key in trunk lock if no remote), you should hear the motor driving the pump, if not, listening carefully, push button again and you may hear a faint click of the relay trying to start the motor, if you hear the relay click and no motor noise, replace or rebuild the PSE,
I rebuilt their module.
