Kompressor from C230 in a C280?
Old Jul 4, 2009 | 07:31 AM
Kyke_ona_Byke's Avatar
W203, W204
will the kompressor from the c230k work in a regular C280? can it be installed? would it increase HP? thanks
Old Jul 4, 2009 | 12:36 PM
tex07's Avatar
2000 C230 sport
why not just get a c36/c43?
Old Jul 4, 2009 | 04:30 PM
AcousticplayerJ's Avatar
2000 c230 Kompressor
I'm not sure if it can be done, but it probably can be. The thing is, the supercharger usually runs on a different belt than other components, such as the alternator. Also, I forget, does the c280 use premium fuel? If so, you will get an increase in power with a supercharger. However, keep in mind that a supercharger actually sucks away engine power to run in the first place. However, the output levels will more than make up for that. Also, a supercharger will increase fuel consumption. If it can be fitted, I'd say go for it. Superchargers are pretty sweet
Old Jul 4, 2009 | 08:59 PM
PhilfromPA's Avatar
300E 3.2
+1
Old Jul 5, 2009 | 09:25 AM
W203, W204
bekoz they cost munnie
Old Jul 6, 2009 | 07:32 AM
rfoo's Avatar
1994 C220
Getting a supercharger will also cost money. You'll probably put up alot of dough doing all the upgrade than buying a c36. I maybe wrong but I think the psi boost of the c230K is at 4psi. That would probably give your c280 additional 46HP or lower. C36 can produced 280HP stock.
