Routine maintenance ?
Benzo
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hi all,
Nothing has gone wrong on my 98 C230 yet, but I feel like I should be doing some routine/preventative maintenance on it (especially the parts that i've read on here that are prone to failure)....
So far i'm going to order (taken from http://www.autohausaz.com)
1) Thermostat (part #1112000915)
2) Air mass sensor (maf?) (part #0280217114)
3) Crankshaft Position Sensor (cps?) (part # 0281002123)
Are these the correct parts that I should be ordering? Is there anything else I should order?
Thanks in advance!
Thanks in advance!
1 Post
97 C28
Hell yea you betta Grease all the Bearing in the axels change the diff oil flush the tranny and grease everything you can find...or pry too....Listen TO me Flush all the fluids **** gets expensive and **** the man who ever said if it aint broke dont fix it hes full of ****..maintainence is key to survival and man dont survive unless hes ready for disaster. Keep that 202 mint
Lata
Lata
I don't understand how half of $tallion's posts are jibberish, and the other half normal?
Thermostat is a good item to replace when flusing the coolant, you could also upgrade to the 79 degree version if you wanted to.
Obviously if you don't have service records it is a important to start with a good maintenance overhaul, but I wouldn't necessarily go overboard. The checklist for the B service is a good reference to start with. If you aren't experiencing problems, then I would save the hundreds you'll spend on the maf & cps towards future repairs.
Benzo
and the only major issue i've had besides a fluctuating temp gauge (which i'm told is normal in a Benz) is this:
https://mbworld.org/forums/c-class-w...ing-issue.html
still think I should forget buying the parts?
Thanks in advance
How many miles are on your car? Those items you quote are common failure items as cars age but some cars go a long time before those parts need replacing. The thermostat is probably a good call for sure. The others may be a bit overkill considering the costs. CPS would be a piece of mind I guess. The tensioner and pulley are other common problem items over time. I would get a serpentine belt, transmission fluid+filter+gasket set, air filter, cabin filter, oil filter, bottle of power steering fluid to change all of those if nothing has been done for a long time. Get the charcoal impregnated cabin filter.
Benzo
I guess i'll definitely order the CPS and Thermostat - are the parts I listed in my first post the right ones?
Thanks for the other tips, I will also keep those in mind.
2000 C230 Kompressor Sport
Lata
Lata
