Ac issues
Old Aug 3, 2009 | 09:55 AM
usaims's Avatar
98 e320
Ac issues
96 C280
The compressor is tempermental and it has a mind of it's own. Sometimes it kicks in imeadiately, sometimes it takes 30 minutes.
No leaks detected and full of freon.
I'm also getting 'engine light' P0411, I don't know if it's related?
The two little fans in front of the radiator are getting louder but it works.
Could these little fans (maybe going bad) be the culprit?
usaims
Old Aug 4, 2009 | 02:56 AM
rfoo's Avatar
1994 C220
Might be the magnetic clutch of your A/C is going bad. I'm not sure if you can purchase that item seperately.
For the fan, usually that only turns on when the engine is really hot. check your visco fan so it wouldn't work overtime.
Old Aug 4, 2009 | 09:38 AM
usaims's Avatar
98 e320
Those two little fans in front of the radiator kick on as soon as the compressor kicks in, is that normal?
Old Aug 4, 2009 | 09:57 AM
rfoo's Avatar
1994 C220
maybe in the newer model. but for mine, it only turns on when the engine is hot. The low fan turns on with the compressor, but the high fan doesn't turn on until my temp gets to 110 degrees celsius.
Old Aug 5, 2009 | 07:26 AM
usaims's Avatar
98 e320
According to a indie, they are suppose to turn on at 212 degrees Fairhenhiet. It's probably my AC Control UNIT going bad.
Does anybody have an extra ac control unit they want to sell?
usaims
