99 C230 Kompressor only 40K miles/wheels?
1999 C-230 Kompressor
Time to put some new tires/shoes on her and decided to go ahead and update the wheels to 18" inchers while I'm at it.
I HAVE used the search feature for two solid days but the variables involved have given me a whopper headache.![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
It's only 4:15 AM too !
Out of desperation I'm going to ask you fine folks some stupid questions and I hope someone will help me out here.
I have a chance to buy some very nice used 18" x 8" wheels in the style I have been looking for at a great price.
It obviously will not be staggered and the tires will be new Yokohama 225/40/18.
The offset on the new wheels is undetermined exactly but is between 35mm to 42mm.
I think the stock Kompressor wheels are 35mm to 37mm depending where the info is located??
The 18" wheels have the correct 5 x 112mm lug pattern.
They originally came off a 1999 Audi A4 and the Audi had a center bore of 57.1mm
I know the C230's center bore is around 66.56mm
Will this be a deal killer or are hubrings the answer here?
My other concern (one of them) is whether I will have clearance issues on the front strut or anywhere in the rear.
(very little clearance in the front even running bone stock wheels)
I would like to avoid running any spacers on the car if possible.
And yet I wonder if the car will end up looking wrong or jacked up like a Gangsta 4 x 4 if the stock suspension remains intact.
If anyone has this similar set-up or knowledge as to whether this combination is fine or ill advised please let me know what you think.
It is GREATLY appreciated !!
Gonna take a few aspirin and get some sleep.
Thanks In Advance.
Thanks In Advance.
lots of cars
You can have the center bore machined, but the problem with audi wheels is also that they use a 14mm lug bolt. You might want to lower your car before going with 18s. I have a nice set of SLK 16" wheels and if you want a more conservative look go with 17s.
BTW, 18x8 35-42mm off fits fine with a 225/40/18 tire... I have a staggered set with 255/35/18 on the rear
thanks
These wheels turned out not to be Audi specific and have a 76mm center bore.
So with some hubcentric 76mm to 66.56 rings they should work out fine with no machining.
The machining was never even a viable consideration or option to me.
Very glad to confirm that the 18x8 35-42mm off fits fine with a 225/40/18 tires.
I'll put'em on and see how she sits.
If it looks like a doggone 4x4 I'll obviously have to reconsider lowering her.
I appreciate your reply very much.
