Directions on accessing the heater core
Old Dec 11, 2009 | 04:07 AM
$tallion's Avatar
97 C28
Cool Directions on accessing the heater core
does anyone have anything on getting to the heater core...?
Old Dec 11, 2009 | 10:34 PM
Shottas's Avatar
1998 C230
do you mean the blower motor and sensor for your heat and fans?
under your glove box take off the panel and its like 4 screws to your fan and your cabin filter is in there too
Old Dec 13, 2009 | 04:53 AM
$tallion's Avatar
97 C28
The actuall heater core i'm smelling a leak (very distink smell only when heats on ) when the heats on i gotta check the actual core
Old Dec 13, 2009 | 09:38 AM
MBtech1098's Avatar
10 speed bicycle
Dash has to come out, cross brace needs to come out, ac needs to be evacuated, coolant drained or clamped off, remove hvac box and seperate.
Old Dec 13, 2009 | 02:50 PM
$tallion's Avatar
97 C28
yeayea i'm talkin the easy way not the junior memeber MBtech way...
And what i mean by that is i think theres lines going into the heater core All i wana do is check the lines going in and out...
rude is my nature...
dont take it personal
Last edited by $tallion; Dec 13, 2009 at 02:52 PM. Reason: Cause i haft to be specific...
Old Dec 13, 2009 | 03:44 PM
MBtech1098's Avatar
10 speed bicycle
Aight mista I wanna be a ganksta. What is it you want to check with the lines at the heater core? If they are leaking. There is no easier way to R&I the heater core then what I explained.
Old Dec 13, 2009 | 10:23 PM
$tallion's Avatar
97 C28
it smells so bad i swear its like a leak when the blowers on u can smell a bit of either freeon or radiator fluid
Old Dec 14, 2009 | 04:51 PM
YNVDIZW124's Avatar
lots of cars
That's what you pretty much gotta do. You can also clamp off the heater and just run without a heater...
Old Dec 14, 2009 | 05:38 PM
MBtech1098's Avatar
10 speed bicycle
Refrigerant and coolant have to distinct smells, evaporators are pretty common though
Old Feb 11, 2020 | 02:39 PM
BenzGirl*'s Avatar
2011 C300 Luxury
Directions to Change heather Core Hoses
The site below helped me learn more about how to get to the heater core, i have a 2011 c300
https://www.pelicanparts.com/techart...eplacement.htm
Old Feb 11, 2020 | 06:08 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
You're responding to an 11 year old thread?? ....regarding your w204 c-class??
And you do realize this is the w202 forum.
Old Feb 12, 2020 | 10:07 AM
BenzGirl*'s Avatar
2011 C300 Luxury
just realized that. Thx!! Lol.
Old Apr 8, 2020 | 07:58 PM
twinturbov12's Avatar
04 sl 600,04 cayenne turbo,king ranch dually.
HELLO BENZ GIRL.
Old Apr 9, 2020 | 03:23 AM
W202_NY's Avatar
2000 C280
check the coolant lines that pass thru to the firewall area, there are some video's on how to find, clean, repair those 2 hoses, and the pass thru
Old May 30, 2020 | 12:54 PM
david nunez's Avatar
2005 Kompressor
Heater core hose bypass
Wow what an old thread, but maybe some one might learn something. Heater hose to the firewall broke (plastic connector). Leaked out all of the coolant and having to tow the car home. To repair and put back the hose looked difficult, if not expensive. Having to remove the dashboard and what not. It took me a while but I figured out where the other hose that led to the heater core was and was able to just bypass the heater core all together. Once I found it was basically a few minutes and done. Sure I have no heater, but I'm Miami I never would have to use it anyways.
