98 C230 is going crazy
Old Dec 16, 2009 | 07:28 AM
kiddhan625's Avatar
2002 S-430
I am having a big time issue with the car. For no apparent reason the windows on the car magically go down on their own. The other night I locked the car as I normally do but the next morning when I came out the windows were down. All 4 of them. Also the alarm on the car keeps going off at random. Sometimes it is fine and other times will sound off a few minutes after alarming the car. Anyone else had this issue or something similar? I have also noticed that the interior central locking button is always red. Even when the car is locked it is lit up solid red. Any help or input would be appreciated. Thanks
Old Dec 16, 2009 | 04:26 PM
YNVDIZW124's Avatar
lots of cars
Change the window switches. What do u mean the central locking button? Is it the trunk light on the shifter?
Old Dec 18, 2009 | 09:52 AM
kiddhan625's Avatar
2002 S-430
I am referring to the lock/unlock switch on the center console that allows the door to be unlock from inside the car.
Old Dec 19, 2009 | 05:54 PM
YNVDIZW124's Avatar
lots of cars
Hmm, that does sound strange. I start by checking the fuses and removing one by one to see if there's some kind of electrical short. You need to isolate the problem and then diagnose from there.
Old Dec 22, 2009 | 07:57 AM
kiddhan625's Avatar
2002 S-430
Thanks guys. It appears the pse module/pump is bad! Any ideas on where online I can get one?
Old Dec 22, 2009 | 08:10 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Try here : http://www.autohausaz.com/
Old Dec 23, 2009 | 07:55 PM
maksi's Avatar
2020 GLC200 (X253) 1995 mb W202 C220, 2008 Mitsubishi Lancer Evolution, 2014 Ford Mustang 5.0
dude,
try to have it serviced first. i had the similar problem prior and i tried to fix it.
first, i opened the module and checked the electric motor and found out that i had a busted motor. i had it rewound cost about $10.00 in my local electrical shop.
second, i re-soldered all the electronic components on the PCB module and voila! works perfectly.
just be careful where you detached what wire from and when re-attaching it again, it may cause some confusion when you install it back again in the system.
if all else fails, try looking here:
http://cgi.ebay.com/ebaymotors/ws/eB...8929&viewitem=
Old Dec 28, 2009 | 10:59 AM
benzo23's Avatar
2009 335i M-Sport Package, 2003 Ford Excursion Limited, 1998 C230
ghost car, haha....sometimes my c230s trunk will just randomly open, in driveways, stop lights, parking lots...ive learned to keep my golf clubs in the back seat if i ever use that car...
Old Dec 28, 2009 | 06:51 PM
kiddhan625's Avatar
2002 S-430
Thanks Guys. The indy thinks it is the master window switch. He will be replacing it tomorrow. So let's see what happens.
