MAF question
Old Jan 24, 2010 | 02:21 AM
xvvvz's Avatar
C230K
You can't order from Autohaus? Bummer. Would your local place let you try it and return if it did not help? It is so hard to diagnose the MAF/o2 sensor chain.
Old Jan 24, 2010 | 03:00 PM
RPin's Avatar
97C230
Maf
I don't thrust E bay seller when it comes to M B parts, thats why i order a Bosch MAF from Getcoolparts.com @ $149.00 shipped free in Calif. You can't be wrong on an original parts.
Reg. idling problem, why not connect scanner (OBD I not II based on your car model) to see what codes it throw?
Old Jan 25, 2010 | 03:48 AM
rfoo's Avatar
1994 C220
Ok, so I sent back the one on ebay for a money refund. Bought a Bosch for about $300 and tested it. Idling still plays a little but not as bad as the one I got on ebay. I drove it for about 50 miles or so and work great except again for the idling. It plays from 700-800rpm so I'll probably get a computer plug to my car what it says.
I can order from autohaus but I don't have much time since I only have one car and can't afford to let the car bug down at the moment. I really need it since I'm handling 2 restaurant stores quite far from each other plus I'm getting a new house constructed.
Old Jan 27, 2010 | 12:30 PM
wesrick's Avatar
1998 C280
rfoo, did the bosch take care of the idling movement completely?
As I drive mine with the new MAF sensor, the idling problem either went away, or I don't notice it.
But, I do notice that the cold affects it. As the days have gotten colder, it take a little more time to warm up (and not sputter), but as soon as it warms up in the slightest, the sputtering goes away. (temps are currently about 20F, which I think is about -6C)
Old Jan 27, 2010 | 01:48 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Originally Posted by rfoo
Hey Wesrick,
Do you have any DIY on how to replace the MAF sensor itself? I can't get the screw out and don't know what the right tools are. Thanks.
Most MAF inserts require a Torx Plus bit. Torx Plus bits have 5 points not 6 as Torx. Also, bit must have security pin hole in center. As a work around you can use a pair of pliers on the shoulder of the fastener head.
Old Jan 28, 2010 | 12:03 AM
rfoo's Avatar
1994 C220
Yup, completly fixed the problem now. I think it has a learning curve and needs a reset to smooth the idling problem. It works just like the original now.
Thanks for the info, I'll keep that in mind for future reference. I just bought a brand new bosch and plugged it. Works perfect now.
