Sunroof Problem
Old Dec 21, 2009 | 08:00 PM
rennwerkes's Avatar
2001 E55, 2002 ML55, 2002 SL500, 2003 CLK55
Sunroof Problem
My sunroof on my 97 C280 will only move backwards about eight inches and then stop. Any clue to why its doing this?
Thanks!
Old Dec 22, 2009 | 02:15 AM
LawRens's Avatar
43
Needs to be resynched. Put the key in the ignition to the "on" position, but no need to turn it on. Push and hold the sunroof button so the sunroof tilts up, and hold that position without letting go for 10-15 seconds. Voila, everything should be done.
Old Dec 22, 2009 | 03:43 AM
rennwerkes's Avatar
Tried it. Turned key to no. 2 position and held sunroof button in tilt up position. Still the same. Sunroof backs up about eight inches then stops.
Thanks for the suggestion.
Old Dec 22, 2009 | 01:31 PM
LawRens's Avatar
43
Read the manual, it should say the same thing.
If not, it's probably not a synch problem, and maybe you got some **** stuck in there lol
Old Dec 22, 2009 | 10:02 PM
nikrox's Avatar
85 280GE; 2001 E55; 2003 CLK
you might have a bent spring from the deflector that prevents it from sliding back
_n.
Old Jan 10, 2010 | 02:11 PM
MarrsCars's Avatar
'99 c230 Kompressor
You may want to disassemble it and lube the parts. As our cars age the sunroof can fail due to friction. Of course it's better to lube the rails and pivot points regularly, I do mine once a year, rather than to have to deal with it once it begins to stick.
Old Jan 10, 2010 | 06:10 PM
LawRens's Avatar
43
... woops.
haven't done any of that in the 12 years ive owned my c230 lol; luckily no problems other than resynching have occurred.
Old Jan 11, 2010 | 12:40 PM
MarrsCars's Avatar
'99 c230 Kompressor
... woops.
Hehe, well like any moving part especially one without bearings, etc. it's a good idea to do some basic preventative maintenance. The good news is now that you have the information you may never have a sunroof problem. The mono-wiper mechanism is another of those easy-to-do yourself lube jobs that can save you lots of cash down the road, but that's another thread.
