1995 C280 HEATER/AC QUESTION
Old Dec 30, 2009 | 03:20 PM
KennyMBZ's Avatar
1995 MBZ C280
1995 C280 ONLY 110,000 MILES, HEATER AND AC WORK FUN GOES FROM HIGH TO LOW, BUT NO MATTER WHAT SETTING (FACE, FEET, DEF) I PUT IT ON IT ALWAYS ONLY BLOWS OUT THE OUTER SIDE VENTS (BY WINDOWS) AND OUT OF THE DEFROST (FRONT WINDSHIELD) I CANT FOR THE LIFE OF ME FIGURE OUT WHY... ANY ONE?
THANKS IN ADVANCE
KEN
Old Jan 2, 2010 | 12:00 AM
xvvvz's Avatar
C230K
Sound like you have leak(s) in the pnuematic system that controls the air diverters in the dash. Common issue in these cars as they age. Split hoses, bad connectors or bad distribution blocks are common. Over-engineering gone bad. Often requires that the whole dash is removed to access the bad components, especially if you are talking about the middle vents.
Old Jan 2, 2010 | 12:34 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Not so , OP-check along the firewall for any loose or crack lines.These vacuum lines are the size of washer fluid lines (small).
Old Jan 2, 2010 | 02:16 AM
KennyMBZ's Avatar
1995 MBZ C280
yes... talking about the middle vents.. also the feet both dont work. only sides and defrost. so ill look for vacuum hoses gone bad is that about all it could be? or possible electronic issues?
thanks
ken
Old Jan 2, 2010 | 02:20 AM
C43AMG's Avatar
Veteran: Army
thanks
ken
More than likely vacuum issues.I would start there before you rip the dash apart.
Old Jan 2, 2010 | 02:24 AM
KennyMBZ's Avatar
1995 MBZ C280
thanks very much.. i will do that soon... lol. night.
ken
