My c280 , 1995 doesn't downshift. E / S switch?
Old Jan 12, 2010 | 05:51 PM
musicalude's Avatar
mb
Smile My c280 , 1995 doesn't downshift. E / S switch?
auto
Last edited by musicalude; Jan 13, 2010 at 07:32 PM. Reason: first time question and I get answer that change car!
Old Jan 12, 2010 | 06:41 PM
onebadclk55amg's Avatar
2003 CLK 55 AMG
Get a c36 or c43 the c280 is a family car not dissing it but its not a hotrod by any means
Old Jan 22, 2010 | 05:26 PM
Sniper73's Avatar
W202 C280
Please describe exactly.. Economy / Standart knob is not responsible for that problem.
Does your kickdown not work ? In econ mode it wont work fine only with full pull down.. in standard it works faster and better.. normaly
Old Jan 27, 2010 | 08:49 PM
mbtechny's Avatar
97 c280, 01 ml320, 04 r32
check the vacuum distribution block in the right rear of the engine compartment. should be next to the engine ecu.the block may leak on be cracked.
Old Jan 30, 2010 | 01:16 PM
bennesspipers's Avatar
'95 W202 C220,'96 W210 E230 Est
Do you mean it wont change down, or, wont kickdown (using throttle pedal)?
