w201 vs. w202
Thank you so much
as far as i can tell, no one here has made that comparison. i would suggest that you try visiting the 201 thread and try to make the necessary comparison in contrast to your experience with the 202.
good luck.
If it is only the rear I would be curious if the rear was aligned since you've owned it? Sometimes people neglect this and only attend to the front wheels.
I've had both a W201 1.8 and 2 W202's and a W124 (260) the cars felt very similar in road manners to me, over here people with 201's say it was the last great car built to Mercedes Benz standards and ever since then they were cost cutting, which i think is not the case.
Of the W202's i had an Elegance auto and an Esprit 5 speed with the sports chassis. Both were C 180`s and were as you put it planted, the old 124 with 280,000 miles on the clock was well worn but still good, no wandering issues at all.
The rear suspension has 4 links each side iirc maybe a rubber bush as worn? or like someone else posted it's a subframe mount?
Mine were all ver regularly maintained, servicing by myself and issues by a local indie.
I'm looking for another C Class now, i could buy newer but i love the value of the old W 202 they are really cheap over here.
I also had a 87 190e and with dead shocks it handled well! I think they both handle well when they are in good shape. The only problem with my 190e is that it tended to eat up the rear camber strut arms all the time.
If you can get under the car you can check all the bushings yourself. Use a big screwdriver or prybar and move around the suspected part and see how much they move. They should not move too much.
