I find it hard to believe
1 Post
1999 C280 Sport
That so many people read this board and no none can answer a question as simple as fuse locations or relay locations. Seriously now no one knows tha answers ??
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
SL600 r230, SL600 r129,, SL500 r230, ML320, C280 Sport, 190e 2.3 16V (2)
Don't you have an owners manual? It's in there.
FWIW, on my 01 e430sport, fuses in the normal place in front of the driver, some under the rear seat with the battery, some at the left end of the dash, right next to the door, and a few in the electronics box in front of the pax.
1 Post
1999 C280 Sport
I have an owners manual but there is a relay that has 4 different relays to operate different things I am trying to get the horn and the w/s wipers to work. Checked all the fuses and there is NO power what so ever to the W/S wiper motor. Mine is a 99 Clas 280 sport.
Is there a compartment with the relays in it?There may be a cover to lift off of something in there that may have some ATO type fuses or strip fuses under the cover.There may also be one next to the main fuse box in the engine compartment.
Sorry I can't help you specifically.
The service CDs from Mercedes are not that badly priced - I think less than $125.00.
Or maybe you can find a pirate disc on ebay if you are so inclined.
The manuals usually have a section showing where evry single compnent is located, and schematics.
may be well worth the $$$.
1999 C280 Sport
ji just know of 2 fuse locations on my c280 sport 1 under hood in front of power brake resevior another next to the battery in the trunk which does have a designation chart on the inside of the lid.........the manual also mentions a accessory fuse location located in front of the coolant resevior under the hood but i swear i cant locate it......you may just want to start pullin fuses@ random to see if one is blown..........just make sure you have your radio security code because once you pull that one you will need it to get your radio back on I do have a manual on PDF if you need it e-mail me jjtoler@windstream.net
