C280 1996 Coil problem- loosing spark to #1
Old Apr 25, 2010 | 05:56 AM
kleinkak's Avatar
Mercedes C280 sport 1996
Can anybody tell me what can cause this? On my C280 straight 6 1996 the third coil (on #6) dies to #1. I replaced it twice, but after a few days this happens again. I tested the coil by removing it from #6 and #1 plugs, and adding loose plugs to it. I earthed the plugs to the engine and cranked it. The result is that only #6 sparks and #1 is dead. Thus only half the coil is working. I have never seen that only half the coil could work.
Old Jun 4, 2010 | 07:20 PM
Paul Fitzgerald's Avatar
C280 1995 W202
I have a similar problem and have tested the coils and they are all working well but no spark from rear of the three coils I presume this is because no 12v feed to the coil. I am going to check out the low tension side and trace the fault back from there but have seen little information on the net about this. The wiring seems to be in very good condition but could be breaking down in the engine harness. The center four cylinders are firing well but 1 and 6 and dead with no spark. This was intermittent but now a permanent fault.
Kleinkak Did you find out what was wrong or anyone out there have any ideas?
1995 C280 W202 engine.
Old Jun 4, 2010 | 10:23 PM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
Wire harness - wire insulation probably all cracked and deteriorated. Check the individual wires inside the loom.
Old Jun 7, 2010 | 01:26 PM
C280 1995 W202
Yes I am sure it is a fault with either the wiring or the control unit but the wiring looks like new with no fading or deterioration so I am not happy starting cutting it up and rewiring it. The fault is intermittent but moving the wiring does not seem to affect it. So could it be the control unit or another sensor somewhere I wonder? But then again it is most likely the wiring even though it looks good. I think I will cut into it this evening a little more.
