I tripped the SRS hard fault code. 1994 c180
Had the airbag/steering wheel/instrument cluster out and started the engine to locate a leak behind the instrument panel...
Did not know that will make a hard code fault for the airbag.
So now the SRS light is constantly on!! Turns out I have to get it reset with equipment. I thought it was OBD2 but a friend said the 94 does not have an OBD2 port...??
What do I need to buy to be able to reset the trip code for the SRS light?
IS it OBD2 or OBD1?
Either way, where is the connection located in the car?
Thanks in advance.
By the way, European car. Im in Norway. IF that matters.
IS it OBD2 or OBD1?
Thanks in advance.
IS it OBD2 or OBD1?
Thanks in advance.
IS it OBD2 or OBD1?
Thanks in advance.
How do I do that?? :P
the alldata info it says remedy is:
"Wiring, Short to circuit 31,30,15,15r. "
After reviewing the picture of the wiring included (which I uploaded here) I found the 30 is the Airbag/SRS..
So how do I short pin nr 30? Which of the pins do I connect it to?
Also do I need to have the key in position 1 ,2 or off while doing this?
Here is the drawing:
http://img404.imageshack.us/img404/2879/srsz.jpg
Thanks for any help in advance
