Wheel help?
Old Oct 20, 2010 | 03:01 AM
jagata's Avatar
S6 LP640 E500
Wheel help?
Looking at some rims will these fit the w202? 19x8.5 5x112 ET35 and 19x9.5 5x112 Et30 Thanks in advance.
Old Oct 22, 2010 | 12:01 AM
YNVDIZW124's Avatar
lots of cars
Yes they will fit. You'll need to trim the inside plastic on the front and roll the fenders if lowered.
Old Oct 23, 2010 | 12:35 AM
jagata's Avatar
S6 LP640 E500
Thank you
Old Oct 23, 2010 | 01:47 PM
ohlord's Avatar
You sure
that you don't have those offsets flipped around?
Normal stagger would call for the 30et to be the front rims.and also the front rims would be the narrower set.
Also depends what tire size and profile you install.
Old Oct 23, 2010 | 03:00 PM
jagata's Avatar
S6 LP640 E500
You are probably right about the offset, it was a copy and paste from their ad.
Old Oct 23, 2010 | 03:39 PM
YNVDIZW124's Avatar
lots of cars
Those offsets sound better than having a +30 offset on the front. I had to use spacers to make the rear wheels sit flush with my w210 e55 amg wheels. I'm running 18x9 +25 and 18x8 +30 front. I can go as low as +20 on the rear and +25 on the front with rolled fenders. I'm lowered on H&Rs. You can mess with different offsets, you'll just need to change to a different width tire.
btw, those giovannas on that s550 look pretty good and agressive .
Old Oct 23, 2010 | 06:45 PM
jagata's Avatar
S6 LP640 E500
Thanks the Giovannas are sold (only put 200 miles on them) I have a different set now but no updated pics.
I just bought a c220 for the family to share whenever someone needs it, but it needs a drop and rims so I am on the look out for cheap Amg replicas.
Old Oct 23, 2010 | 07:06 PM
YNVDIZW124's Avatar
lots of cars
Go with 18s instead, tires are cheaper, last longer, and better ride too. 19s on a 4cyl isn't the best thing to do either.
Old Oct 23, 2010 | 07:18 PM
Jovsky's Avatar
2000 C230 Kompressor Sport
Do you need AMG Replicas? Check this link, they have lots of AMG style replicas: http://www.323motorsports.com/SearchResults.asp?Cat=294
Old Oct 23, 2010 | 07:23 PM
YNVDIZW124's Avatar
lots of cars
That's pretty expensive for replicas. Try ebay.
jagata's Avatar
S6 LP640 E500
Yes 18's is my first choice, but the 19s was a thought if I could get them real cheap. Thanks
Old Oct 23, 2010 | 07:31 PM
Jovsky's Avatar
How about 18" Original Brabus Monoblock VI Wheels? Check this link: http://losangeles.craigslist.org/sfv...011558213.html
Old Oct 23, 2010 | 10:20 PM
jagata's Avatar
S6 LP640 E500
I think I will go with these, they are very cheap and fit the older body more to my taste.
Old Nov 17, 2010 | 10:09 AM
Chappy's Avatar
AMG
Check my sig if you want the real deal Monoblocks.
Old Nov 19, 2010 | 05:21 PM
jagata's Avatar
S6 LP640 E500
delete
