W202 outside mirror housing removal
Subscribe
Oct 26, 2010 | 07:41 PM
How, how, how do you remove the outside mirror housing to get at the mounting and mechanism?
Reply 0
Oct 26, 2010 | 08:50 PM
you have to remove the mirror glass first by tilting the glass down all the way and unclipping the retaining spring at the top of the mirror motor. then you have to pry the housing away from the frame.
Reply 0
Oct 26, 2010 | 09:13 PM
No, you don't pry it off. Since I posted my question I discovered that you must push the mirror against its folding spring until you can see the black frame. Under the folding spring (a coil about 1/2" dia.) is a silver U-shaped sheet metal part about 3" across the open end of the U. Under the spot where the spring crosses over it is a point where a screwdriver tip may be used to push the U toward the mirror side to get tips of the U from under the wedges molded on the housing that latch over the tips and hold the housing in place. When the silver latch tips are out from under the wedges molded into the housing then the housing can be pulled off.
Reply 0
Oct 27, 2010 | 09:29 AM
must of got confused with a 203. Sorry. Did you have to take the mirror glass off on the 202 its been a while since i've done one?
Reply 0
Oct 27, 2010 | 11:34 AM
No, the mirror glass can stay in place while the housing is being removed on a 202. At least mine did.
Reply 0
Oct 27, 2010 | 02:15 PM
Following this video intructions:
http://www.youtube.com/user/lucabert.../9/aMKxea8j7E8
Reply 0
Subscribe
Currently Active Users (1)
