18x9 RIMS IN FRONT -- HELP
I don't know Merclover, but common sense says more rubber on the road usually increases your handling since grip on the road is more readily available. NOT less! As for gas consumption, I don't have the facts precisely, but I don't see how an inch or more on a wheel will affect mileage that greatly. Driving habits and conditions should still be the greater factor to consider.
wider tires are only good if it's dry. as well..wider tires will make your car track funny bevause of the grooves of the roads.
if you compare two tires, one say 195 and the other 255, the smallest tire will have less surface area in contact with the ground than the 255, therefore the friction experienced on the 255 tires wil be greater therefore needing more driving force to accelerate and/or keep speeds constant, plus added that this change in size is applied to all four wheels so the force which friction can exert can be significantly bigger in comparison, so the car will suck more gas than before.
about the hydroplanning, only the clumsiest of drivers would need to be concerned about that
Tp, that's crazy. Even if the wheels are five pounds heavier the low profile tire will weigh less to help even it out. I can assure all of you there will be hardly any difference in gas mileage by changing out wheels and tires.
Also, how are your 225/40R18 the same width as your 205/55R16? Using an example tire, like the Bridgestone S-03, the 225 is an 8.3" tread width, and the 205 is a 7.6" tread width... so the newer tire is 10% wider! That's significant. If you don't think 10% is significant, try moving someplace with 10% sales tax.
Oh yeah, did you get your wheels from Tirerack? If so, I recommend replacing the lugs with something real.
-s-
Whose got a 15 by 6 inch rim??? Mine were 15 by 7 stock.
I was asking about the lugs because so far I've broken 12 lugs from Tirerack in about one year. They break in twos or threes, so something to watch for. These are only the cone seat lugs, the ones I got from Tirerack for Carlssons (same as AMGs) haven't broken.
-s-
15 by 5.5??? My 190 comes with 15 by 6.5. What's the deal with your skinny wheels?
-s-
damn scorchie, 15x5.5, wtf are you sure your car isn't a civic?
That wheel is ET49, too. No wonder people have problems when they put ET35 on their 124/201s.
-s-
I put ET 35 on my 190 with no problems at all.
-s-
What's that supposed to mean?
Or, if you just don't know what aggressive means in this context, I apologize. It means your car has skinny tires. And sits high. (Mine sits high too, but I don't run skinny tires.)
Here's a pointer to Merriam-Webster to highlight the meaning of "aggressive". See point #4.
http://www.m-w.com/cgi-bin/dictionary?va=aggressive
By the same meaning... you ARE aggressive when it comes to driving your post count higher. Even if it's by always asking "What's that mean?"
-s-
