How much coolant do the 202's require?
I purchased a gallon, put it in, but when I read the owners manual, it said it holds 10+ liters or 3 gallons. I also don't know where to fill it to, as there is no fill line. Could anyone offer me pointers? Thanks in advance!
FWIW, I just did a coolant flush on my W202 today. A gallon of coolant did the job, I burped the hoses once the reservoir was half full, at which point I burped the hoses and ran the heater a while, then checked the level, which was fine.
How many miles on the car? Thermostats don't last forever, no matter what MB might say... On my vehicle, for example, they say to inflate the tires below the tire maker's specs, and that the transmission fluid never needs to be changed. MB engineers are wrong on two very serious counts there. More to follow as I learn more about the car.
The mechanic who taught me everything I know about cooling engines said you always want the temp around halfway... so FWIW, I'd say you're ok unless there is some special MB temperature, but I've been following the halfway rule for years now, no problems yet.
