Pistons, Rods & Headwork… Oh My!!!
For pics of the Rods & Pistons:
http://www.turbobenz.com/Engine_Parts.htm
For pics of the Head & Block:
http://www.turbobenz.com/Rebuild.htm
Sweeeeeet!
Jason
I was already on par/beating a C36's performance (at least in the quarter mile) prior to doing this new rebuild.
I expect to be in the low 13 second range (hopefully even high 12's) when I'm done with all this.
Jason
How will all this work in your car compatibly with your car's ECU? You must be modifying not only the mechanics of your car's engine, but the computers, chips, and sensors on your C220! By the way, what will be the estimated horsepower once your done modifying your car? I also hope that you get your car dyno tested once all this is done as well...
I wonder if you'll have more horsepower than a C43 (w202) and what your car's top speed will be?
Another concern I have is the reliability of your car?! If this is not an issue, I suppose then that this car is simply for track use only.
I have a perfectpower SMT5i piggyback system that allows me to modify fueling, timing, and run a seperate 5th injector among many many other things... all with my laptop.
I was pushing 241 @ wheels (possibly 260-270@ crank?) prior to this rebuild at 9psi. I intend to run 15psi at the track once this is done, so likely will be well into 300HP (I'm thinking around 320).
However we are building the tolerances for longevity and relaibility as well. If I get the fueling right throughout the boost curve, it should go for well over 100,000.
Jason
300 hp on a C220!!!!!!
Jason
Jano,
Jason
For more info check:
http://www.perfectpower.com/Products/smt6.asp
Jason
At this point if I did a conversion, the cost on this project would be totally out of hand, so I guess I'll have to stick with the slushee for now.
As far as the engine parts & where I got them goes... depends on the part. Most of the info should be out on the website:
www.turbobenz.com
If you have a question about a particular part that's not listed out there just ask
Jason
