Coolant problem and oil
Old Jun 10, 2011 | 06:54 PM
ricky4317's Avatar
c280 sport edition
Well a few weeks a ago on my c280 2000 the coolant light came on I check and added more well it didn't go off and also when I drive around after awhile the oil symbol comes on and says hi I need some help does anyone know what could he wrong ????? Ps also I change my temperature sensor
Old Jun 28, 2011 | 07:04 PM
Russell Ormerod's Avatar
not a merc
headgasket or oil heatexchanger
Old Jul 3, 2011 | 05:33 PM
Jovsky's Avatar
2000 C230 Kompressor Sport
Happened to my 2000 C230 Kompressor too. Coolant light came on and even if I filled it up with new coolant, the light won't come off. Found out that the floater in the coolant container broke off, as such, it triggered the coolant light error. Bought a new coolant container (Part # 202 500 02 49) from the dealer for $76.65 + tax and replaced it myself.
Easy fix. Remove 2 nuts and the hose clamp. Just be careful when removing the sensor wiring from the underneath of the container. You will need to press the clip and pull the clip horizontally to remove it from the sensor. Then transfer the sensor from the old container to the new one and put the clip/wiring back on.
