Duo Valve Question
Old Jun 20, 2011 | 04:51 PM
pc820's Avatar
Duo Valve Question
I'm going to clean or replace the duo valves that are part of the heat and A/C system. Currently from time to time hot air comes out of the side vents while cold comes from the center.
Once I remove the duo valve cover for cleaning, does anyone know if I will have to recharge the A/C system?
Thanks....
Old Jun 21, 2011 | 01:06 PM
vinceC's Avatar
2014 ML350 4Matic
No. The valve regulates the flow of coolant through the heater core. It has nothing to do with the refrigerant cycle.
Old Jul 6, 2011 | 11:26 AM
pc820's Avatar
great, thank you
Old Jul 7, 2011 | 08:34 PM
Ali Daei's Avatar
97 C280
I have a question. if i completely remove the duovalve will the ac still work?
Old Jul 8, 2011 | 08:07 AM
vinceC's Avatar
2014 ML350 4Matic
No. Coolant will flow unrestricted into the heater core negating the cooling effect from the evaporator. You would have to block the coolant lines and then the heater won't work.
