1996 C220....ANOTHER A/C PROBLEM
Old Aug 3, 2011 | 02:24 PM
RWB1's Avatar
C220
This is my first Benz so be gentle......a/c no working...blows warm. I thought maybe low on freon.....I should have read the forums first.
Having searched I learned that I need to re-set the climate control fault codes to re-set the a/c? I dont want to buy a new compressor if I dont need it....Im going to try and read the values thru the climate control tonite....wondering what to look for as far as a bad evap sensor or compressor.....and how do I re-set the system?
Any help is apprediated.....also EC light is always on..
Old Aug 4, 2011 | 07:28 AM
Russell Ormerod's Avatar
not a merc
EC always on = low gas
Old Aug 4, 2011 | 08:45 AM
RWB1's Avatar
C220
Thanks for the reply......I forgot to mention that I did put in 1 large can of freon...
Clutch doesnt spin....I have read conflicting posts about re-setting the system....? Does this need to be done....and if so..how do I do it..?
From what I have read the evap sensor is a common problem in these cars...what #'s am I looking for on the climate control read out pointing to a bad sensor..?
again...thanks in advance for the help
Old Aug 6, 2011 | 10:43 AM
not a merc
you may need to reset the module with a scan tool. not sure if can be done onboard,because i never do it that way. Post a pic of your ac panel so i know what panel is fitted
Old Aug 8, 2011 | 03:38 PM
eundaddy's Avatar
1998 Mercedes-Benz C43 AMG
press and hold the rest button.
