DTC P0105, MAP Sensor?
Old Sep 10, 2011 | 02:07 PM
AGGRAVATED's Avatar
1999 C230 Kompressor
CEL came on recently, auto parts store scanner says it's P0105, Manifold Absolute Pressure sensor. No idea where the MAP sensor is on this vehicle nor where else to start. Would really like to avoid bringing it to someone if possible.
Please advise
Old Sep 11, 2011 | 11:58 AM
AGGRAVATED's Avatar
The problem causing the P0105 code turned out to be a damaged vacuum hose. The hose that plugs into the MAP sensor had a tear in it. The fix was super easy: Remove the MAP sensor, remove the relevant support bracket to gain easy access to the vacuum hose, replace the vacuum hose, then bolt it back up.
Thanks for all the replies!
