Thermostatic issues
Old Dec 7, 2011 | 08:15 AM
DeonjoubertCT's Avatar
1995 W202 C280
Thermostatic issues
Hi all
Hoping to get some help with the following issue. My passager side heat is not working at all, driver side is fine. I have no idea where to start. I also have the issue where when I opperate the aircon, then the centre vent stops working under throttle, but when slowing down and taking my foot off, it starts to blow through the centre again.
Many thanks
Old Dec 7, 2011 | 08:28 AM
1995 W202 C280
Not Thermostatic???
Well, it seems I have my terminology mixed up....I have the an old 94-95 C280 with the two twirl buttons for temp changing.....dont know if this system was called Thermostatic??
Old Dec 7, 2011 | 06:22 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
If airflow in changing with the throttle you'll need to rectify the vacuum leaks before diagnosing the heater. Start with the vacuum block in the engine bay between the 2 firewalls with the large number of vacuum fittings. check each one individually untill you know which one doen't hold vacuum then keep chasing.
Old Dec 9, 2011 | 04:28 AM
1995 W202 C280
Thanks for the reply ...I'll do just that.
