Question for people w/swapped radios/looking for stock radio
Nobody makes a plug in harness do they?
Does anyone in the DC area have a stock radio to sell? It would be easier for me to find one locally.
Out of the area, email me which radio you have, and what you want for it.
Thanks,
Tad
oh and the hiss... see if the shops local to u couldnt be able to fix that... maybe a bad ground or something. what type of hiss?
it happened to my car when i installed the command. so i went out and bouthg the line output converter.
so then we adjusted the power outtput lower.
I'm not tied tot he 94-96 C280 head units, I'd just like something that will plug in. I checked the crutchfield website, and they don't list a Mercedes radio adaptor other than the W123 series round type. Do I have to call them to get that item?
TP: You used a line converter in between the command and the stock radio?
Thanks for the suggestions,
Tad
I've successfully rewired cars that had the BOSE system and converted the to a "regular" setup (for instance a 1990 nissan maxima a couple of weeks ago) BUT let me tell you it's NOT easy....I went the cheap way and just disconnected the speakers from the BOSE amps and plugged them to the preamp wires etc, but that was a pain.....But, If you planning to keep this can for a while longer.....then by all means swap the whole system and put the old one on Ebay.... I've also done this on my previous car (89 735iL) that had a much more complicated 10 speaker audio system than a W202 and the results were very rewarding....
ps. how did the cluster come out?
I could have sworn that all BOSE head units didn't put out any power at all. That's why the system has individual amps for each speaker. Is Mercedes BOSE set up a different way. I know that my MAXIMA had individual amps tied to all four speakers and the head unit had no power output at all.
On the W202/W208/W210, there is one Bose amp for all the speakers.
If you want to add an aftermarket headunit to a Bose system on a pre-1998 W202/W208, and retaining the Bose system, feed the LINE LEVEL outputs from the headunit to the SPEAKER connector (buy a pigtail adapter from Scosche or whoever your favorite ISO adapter maker is, a VW/Audi one will work fine).
When hooking an aftermarket headunit to a pre-1998 non-Bose W202/W210, or a 1998+ Bose system, the speaker outputs from the headunit can be fed to the speaker connector. On the non-Bose system, the speakers can also be replaced with higher quality units.
This has been my experience. It's best that you try things out yourself to see what will work for you, and what side effects are acceptable or not.
-s-
So, I may try an aftermarket head unit, and the line outputs from it.
So VW/Audio adaptors work eh? Good to know. That will make this transition much easier.
Thanks again,
Tad
I just wanna know, how much wire cutting and stuff is required to switch to an aftermarket head unit? I may do it if it's easy, cause I have a Sony head unit I took out of my old car.
-s-
Where can we get those harness wiring adaptors? Have looked everywhere but can't find one.....
If you can't find them, you're looking too hard!
-s-
..... then looked all over the crutchfield website, and I couldn't find it
(in fact they don't even know what fits the car), also tried a couple of other sites, nothing....link.
will try best buy though...thanksp.s. if it is available in crutchfield can you please post
BTW... you guys think this would be a nice replacement for the factory stereo?
http://www.nakusa.com/master/mb75.htm
well....went to the circuit city near me, no luck (they had for jap. and us cars, and for jetta's i think, no merc.)
I said "buy a pigtail adapter from Scosche or whoever your favorite ISO adapter maker is, a VW/Audi one will work fine."
When you were at Circuit City, did you ask a salesguy? Or did you just look at the wall of adapters? You really need to talk with an installer, the salespeople are just people that come in off the street and get a job.
On Crutchfield, "What Fits" is only for head units, speakers, etc. Instead, go to "Installation" then "receiver wiring harness" and select the Mercedes one. You should just call to verify that it is for a 1994+ model because the years are not listed.
-s-
