For churg
Old Dec 29, 2011 | 09:02 AM
Glyn M Ruck's Avatar
Super Moderator
For churg
churg - please scroll down. Long post:
This is fuel pump rig. 17 is the fuel pressure sensor.
5 A 208 540 00 50 FUSE BOX
RELAY AND FUSE BOX [880]
001 L
5 A 208 540 01 50 FUSE BOX
001 R
8 A 202 545 05 80 GASKET 001 L
8 A 202 545 08 80 GASKET 001 R
11 N 913023 3006001 NUT
FUSE BOX TO FIRE WALL 004
17 A 202 997 33 81 GROMMET
TO PLUG THE FREE OUTLETS AT CASE [880]
001
20 A 202 546 37 43 BRACKET
PLUG CONNECTIONS IN FUSE BOX [860]
001
23 A 208 545 00 03 CAP
001 L
23 A 208 545 01 03 CAP
001 R
29 A 202 545 14 03 CAP
FUSE BOX [066]
001
47 A 208 545 00 40 BRACKET
RELAY [880]
001 L
47 A 208 545 01 40 BRACKET
RELAY [880]
001 R
50 A 208 545 02 40 BRACKET
RELAY [880]
001 L
50 A 208 545 03 40 BRACKET
RELAY [880]
001 R
53 A 019 545 56 32 SAM CONTROL UNIT [880]
001
56 A 002 545 27 01 FUSE BOX
CENTRAL ELECTRICAL SYSTEM
SAM [880]
001
59 A 002 542 03 19 RELAY
PANE WASHER SYSTEM [880]
001
62 A 002 542 11 19 RELAY
TRUMPET HORN [880]
001
65 A 002 542 13 19 RELAY
RETURN FLOW PUMP [880]
001
65 A 002 542 14 19 RELAY
PANE WIPER [880]
002
HEADLAMP WIPER/WASHER [880]
001
FUEL PUMP 001
68 A 202 545 05 46 COVERING
IN FUSE CABINET [860]
001
86 A 001 545 79 01 FUSE BOX
NINEFOLD
F 1-9 [066]
001
86 A 001 545 84 01 FUSE BOX
NINEFOLD
F 10-18 [066]
001
86 A 001 545 94 01 FUSE BOX
NINEFOLD
F19-27 [066]
001
89 A 001 545 96 01 FUSE BOX
DOUBLE
MAXI, F28-29 [066]
001
92 A 001 545 91 01 FUSE BOX
QUADRUPLE
F30-33 [066]
001
95 A 002 545 06 01 FUSE BOX
NINEFOLD [880]
001
95 A 002 545 12 01 FUSE BOX
NINEFOLD [880]
001
98 N 007985 5004125 SCREW
Replaced_By: N 007985 5004107 -
98 N 007985 5004107 SCREW
ELECTRIC CABLE TO FUSE BOX NB
98 N 007985 5005125 SCREW
Replaced_By: N 007985 5005157 -
98 N 007985 5005157 SCREW
101 N 912004 4004102 LOCK WASHER
101 N 912004 4005105 LOCK WASHER
104 A 202 545 30 00 MARKING STRIP
FRONT FUSE BOX [880], [094]
001
104 A 202 545 34 00 MARKING STRIP
FRONT FUSE BOX; IN GERMAN/ENGLISH [095], [881]
001
104 A 202 545 36 00 MARKING STRIP
FRONT FUSE BOX; IN GERMAN/ENGLISH [890], [891]
001
104 A 202 545 40 00 MARKING STRIP
FRONT FUSE BOX; IN GERMAN/ENGLISH [800]
001
104 A 202 545 31 00 MARKING STRIP
FRONT FUSE BOX; IN ENGLISH/FRENCH [880], [094]
001
104 A 202 545 35 00 MARKING STRIP
FRONT FUSE BOX; IN ENGLISH/FRENCH [095], [880], [881]
001
104 A 202 545 37 00 MARKING STRIP
FRONT FUSE BOX; IN ENGLISH/FRENCH [890], [891]
001
104 A 202 545 41 00 MARKING STRIP
FRONT FUSE BOX; IN ENGLISH/FRENCH [800]
001
107 N 072581 1000302 FUSE
5A NB
107 A 002 545 08 34 FUSE
Replaced_By: N 072581 1000303 -
107 N 072581 1000303 FUSE
7.5A NB
107 A 002 545 09 34 FUSE
10A NB
107 A 002 545 10 34 FUSE
Replaced_By: N 072581 1000305 -
107 N 072581 1000305 FUSE
15A NB
107 A 002 545 11 34 FUSE
Replaced_By: N 072581 1000306 -
107 N 072581 1000306 FUSE
20A NB
107 N 072581 1000307 FUSE
25A NB
107 N 072581 1000308 FUSE
30A NB
107 A 002 545 42 34 FUSE
40A NB
107 A 002 545 16 34 FUSE
30A (MAXI) NB
107 N 000000 0000696 FUSE
40A (MAXI) NB
107 A 002 545 19 34 FUSE
60A (MAXI) NB
110 A 000 545 25 02 CONTACT RAIL
FUSE BOX NB
114 A 202 542 02 32 CONTROL DEVICE
Replaced_By: A 202 542 05 32 -
114 A 202 542 05 32 CONTROL DEVICE
LAMP CONTROL 001
116 A 202 545 61 40 BRACKET
LAMP CONTROL 001
119 A 001 542 82 19 RELAY
AUXILIARY FAN Code: 580/581/585/586/587/588
001 L
119 A 002 542 01 19 RELAY
AUXILIARY FAN, STAGE I
15A Code: 580/581/585/586/587/588
001
119 A 001 542 02 19 RELAY
OptionPart_With: A 001 542 22 19 Code: 600
001
BURGLARY ALARM SYSTEM
OptionPart_With: A 001 542 22 19 Code: 551
001
119 A 001 542 22 19 RELAY
OptionPart_With: A 001 542 02 19 Code: 600
001
OptionPart_With: A 001 542 02 19 Code: 551
001
119 A 002 542 22 19 RELAY
ELECTRIC SEAT ADJUSTER [880]
Code: 221/222
001
119 A 001 542 99 19 RELAY
TWO-TONE HORN 001
5 A 202 540 06 73 BRACKET
(GROMMET RAIL) [861]
001
8 A 202 545 03 80 .GASKET
GROMMET RAIL TO FIRE WALL [861]
001
003
14 A 129 997 45 81 GROMMET
GROMMET RAIL [861]
002
17 A 129 997 20 81 GROMMET
DIAGNOSIS BOX 001
20 A 202 540 03 82 COVER
GROMMET RAIL [861]
001
23 A 202 545 04 80 .GASKET [861]
001
38 N 913023 3006001 NUT
BRACKET TO FIRE WALL 003
53 N 304017 7006034 SCREW
BRACKET ON CONTROL UNITSBRACKET [861]
004
---- A 202 545 04 46 COVERING
KICK-DOWN CUT-OFF RELAY [057]
001 A
71 A 202 540 04 24 APPARATUS CASE [870]
001 L
71 A 202 540 06 24 APPARATUS CASE [870]
001 R
72 A 000 545 09 74 PIN [870]
001
74 A 202 540 05 82 COVER
MODULE BOX [870]
001 L
74 A 202 540 06 82 COVER
MODULE BOX [870]
001 R
75 A 000 540 03 82 .COVER
EXPANSION PLUG [870]
001
77 A 202 545 64 40 BRACKET
MODULE BOX [870]
001 R
80 A 202 545 76 40 BRACKET
DIAGNOSIS BOX [870]
001 L
83 N 913023 3006001 NUT
DIAGNOSIS BOX [870]
002 L
86 A 202 540 01 67 CABLE TRAY
MODULE BOX [870]
001 L
86 A 202 540 02 67 CABLE TRAY
MODULE BOX [870]
001 R
89 N 913023 3006001 NUT
CABLE TRAY TO FIRE WALL [870]
003
92 A 129 997 49 81 GROMMET
TO PLUG THE FREE OUTLETS AT CASE [870]
NB
95 A 210 545 41 40 BRACKET
CONTROL UNITS [099]
001
98 A 001 990 82 12 SCREW
CONTROL UNIT FIXTURE
ABS/ASR/ESP 002
116 A 017 545 73 32 ASR CONTROL UNIT
ACCELERATION SKID CONTROL
BOSCH [011], [880]
001
116 A 019 545 31 32 ASR CONTROL UNIT
ACCELERATION SKID CONTROL [012], [880]
001
116 A 019 545 47 32 ETS CONTROL UNIT
ELECTRONIC TRACTION SYSTEM
BOSCH [011], [423], [870]
Code: 212
001
116 A 019 545 43 32 ETS CONTROL UNIT
TEVES [012], [423], [870]
Code: 212
001
119 N 304017 7006034 SCREW
ABS CONTROL UNIT [870]
002
119 N 304017 7006034 SCREW [880]
001
137 A 022 545 68 32 ESP CONTROL UNIT
Replaced_By: A 024 545 05 32 Code: 472
137 A 024 545 05 32 ESP CONTROL UNIT
Replaced_By: A 025 545 61 32 Code: 472
137 A 025 545 61 32 ESP CONTROL UNIT
Replaced_By: A 027 545 59 32 Code: 472
137 A 027 545 59 32 ESP CONTROL UNIT
Replaced_By: A 029 545 70 32 Code: 472
137 A 029 545 70 32 ESP CONTROL UNIT Code: 472
001
ELECTRONIC STABILITY PROGRAM (ESP) [891]
001 M
137 A 026 545 60 32 ESP CONTROL UNIT
Replaced_By: A 029 545 71 32 - M
137 A 029 545 71 32 ESP CONTROL UNIT
ELECTRONIC STABILITY PROGRAM (ESP) [800]
001 M
161 A 020 545 04 32 MSG CONTROL UNIT
Replaced_By: A 023 545 96 32 [006], [429]
161 A 023 545 96 32 ME. CONTROL UNIT
Replaced_By: A 025 545 85 32 [006], [429], [525]
Code: -925
161 A 025 545 85 32 MSG CONTROL UNIT
Replaced_By: A 026 545 65 32 Code: -925
161 A 026 545 65 32 CONTROL UNIT
ENGINE CONTROL MODULE [017], [135], [255], [429], [880]
Code: -925
001
161 A 025 545 45 32 CONTROL UNIT
Replaced_By: A 025 545 87 32 Code: 922
161 A 025 545 87 32 MSG CONTROL UNIT
Replaced_By: A 026 545 67 32 Code: 922
161 A 026 545 67 32 CONTROL UNIT
ENGINE CONTROL MODULE [018], [107], [134], [525], [622]
Code: 922
001
161 A 024 545 59 32 MSG CONTROL UNIT
Replaced_By: A 025 545 86 32 Code: 925-922
161 A 025 545 86 32 MSG CONTROL UNIT
Replaced_By: A 026 545 66 32 Code: 925-922
161 A 026 545 66 32 MSG CONTROL UNIT
Replaced_By: A 112 153 04 79 Code: 925-922
161 A 112 153 04 79 CONTROL UNIT
ENGINE CONTROL MODULE [006], [017], [137], [429], [525]
Code: 925
001
188 A 001 990 82 12 SCREW
ENGINE CONTROL MODULE [880]
002
224 A 008 988 23 78 CLIP
DIAGNOSIS BOX [861]
001 L
236 A 013 545 96 32 CONTROL UNIT
DAY DRIVING LIGHT Code: 236
001 L
239 A 202 540 22 73 BRACKET
CONTROL UNIT Code: 236
001 L
242 N 914031 1004216 COMBINATION BOLT
BRACKET TO INSTRUMENT PANEL CONSOLE 001 L
245 A 202 545 33 40 BRACKET
Replaced_By: A 202 545 48 40
+001 A 008 988 23 78 - L
245 A 202 545 48 40 BRACKET
DIAGNOSIS BOX [861]
001 L
251 N 913023 3006001 NUT
BRACKET TO WHEEL ARCH PANEL [861]
002 L
264 A 016 545 96 32 CONTROL UNIT
ADDITIONAL FAN [860], [881]
001
264 A 020 545 15 32 CONTROL UNIT
Replaced_By: A 027 545 77 32 Code: 580/581/585/586/587/588
264 A 027 545 77 32 CONTROL UNIT
Replaced_By: A 025 545 59 32 Code: 580/581/585/586/587/588
264 A 025 545 59 32 CONTROL UNIT
ADDITIONAL FAN [890]
001
266 N 913023 3006001 NUT
CONTROL MODULE,AUXILIARY FAN [860]
002
Fuel pump cable.
Battery & Starter cables
Attached Thumbnails For churg-w202-front-sam-etc..jpg   For churg-w202-aparatus-case-2.jpg   For churg-w202-aparatus-case-1.jpg   For churg-w202-fuel-pump-cable.jpg   For churg-w202-battery-starter-cables.jpg
Old Dec 29, 2011 | 01:50 PM
Super Moderator
5 A 202 541 00 13 MOUNTING RAIL -
5 A 202 545 73 40 BRACKET
CONTROL UNIT [880], [881]
001
5 A 202 545 84 40 BRACKET
CONTROL UNIT [890]
001
11 A 001 545 79 01 FUSE BOX
REAR END
F1-9 [066]
001
14 A 001 545 99 01 FUSE BOX
REAR END
F10-13 [066]
001
17 A 202 545 08 03 CAP
REAR END 001
20 A 202 545 32 00 MARKING STRIP
REAR FUSE BOX; IN GERMANY/ENGLISH [880], [881]
001
20 A 202 545 38 00 MARKING STRIP
REAR FUSE BOX; IN GERMANY/ENGLISH [890], [891]
001
20 A 202 545 42 00 MARKING STRIP
REAR FUSE BOX; IN GERMANY/ENGLISH [800]
001
20 A 202 545 33 00 MARKING STRIP
REAR FUSE BOX; IN ENGLISH/FRENCH [880], [881]
001
20 A 202 545 39 00 MARKING STRIP
REAR FUSE BOX; IN ENGLISH/FRENCH [890], [891]
001
20 A 202 545 43 00 MARKING STRIP
REAR FUSE BOX; IN ENGLISH/FRENCH [800]
001
23 A 140 990 01 50 NUT
Replaced_By: A 210 990 01 50 -
23 A 210 990 01 50 NUT
FUSE BOX IN LUGGAGE COMPARTMENT 001
29 A 001 542 78 19 RELAY
COMFORT SWITCHING 001
32 A 202 545 51 40 BRACKET
CONTROL UNIT [066]
001
