Instrument Cluster Swap
while browsing on ebay i saw an instrument cluseter from the w210 E Class car and it looks remarkably similar to the cluster from the w202 models...except it has the large lcd display at the bottom of the cluster- would this work in a 1999 c class? if a comand unit were installed, would this work with the comand nav unit? i have sent steve nl an email regarding this install but I wonder if anyone else has researched and/or tried this mod? let me know!
mark
Hey there...
mark
http://www.blancmange.com/scorchie/M...mandC43-09.jpg
I'll have newer pictures in a little while with the completed project.
-s-
greetingz,
that would be pretty sweet
and how much rewiring is required? and how expensive would this run? is it even worth doing in a 99 c230K??
i have seen several w210 and w208 steering wheels on ebay- without the cover and without the airbag of course... could the w202 airbag work? how much would a new airbag unit be? also how much is a cover? buttons? do the buttons for the multifunction display come with the steering wheel cover? are they seperate.? if anyone has a rough outline of the best way to do this... that would be appreciated...
thanks!
so the next question is ... how much?
thanks!
They go away for a little while, come back, and voila... it's done.
That's how I did it!
(OK, I did kinda have to convince him that it would work and he should figure it out... but now, he can do it with his eyes closed.)
-s-
I have several MF airbags in different colors in stock (most of them are new)...in case you want to do the update anywhen in the future (either yourself or have it done).
greetingz,
