W202 95 C280 Transmission Slipping, Jumping Revs
1995 US c280
I'm wondering if anyone would know where to begin with an automatic 95 C280 with a tranny bug. The car has 180k+ and has not likely ever had a tranny flush but a fluid check for color showed it appeared red and 'normal' to the eye. I've never had issues with the engine or transmission before, but the transmission appears to be slipping as if it were a slipping clutch on a manual tranny. What's strange is that it also appears to be revving quite strange under different circumstances. Mainly when going up hill or when the engine is cold, the engines revs appears to jump up and down quite rapidly at only certain speeds making the car jerk back and forth. The only way to get around that is to let off the gas, then push it quite hard till you get over the 'hump'. I've also noticed the car seems to take quite a long time (especially when cold) shifting from neutral to drive, or from neutral to reverse. You can actually feel the transmission 'clicking' into position (roughly 7 clicks) that can take about 3-5 seconds. Since i've owned the car, it has always slipped when going into (and going in) reverse though. Also of note is when going around corners, it appears to slip more readily. A check of the gear oil in the rear diff appeared normal to my local mechanic when he checked it last. I replaced the fuel pump and spark plugs not long too ago when the jumping rev's first appeared, but that did not solve the problem. I want to take the car to a local autozone and have the codes pulled, but I was wondering if anyone has experience or knows a direction to point me with this issue.
I've included a link to a youtube vid i recorded off my phone of the jumping revs and slipping tranny. In the first seconds you can see it rev quite high from a full stop. At this point the tranny is slipping. After catching around 20-25mph, you will notice the camera shake and the tach needle jump up and down wildly before it flattens off. The shift occurs quite shortly after.
http://youtu.be/olPjPdzdh7s
Any help is truly appreciated.
