Broken Side View Mirror
Old Jun 30, 2003 | 01:13 PM
pks485's Avatar
The passenger side rear view mirror on my C230 doesn't work. The only way I can move it is if I push it with my hand. Does anyone know how to fix this problem.
Thanks.
Old Jun 30, 2003 | 01:23 PM
blackmercedes's Avatar
You'll need to do some diagnosis work. The mirror itself might be shot, or perhaps the switch. Check the fuse first. Are you handy with a multimeter? If not, you might be buying some expert time...
Old Jun 30, 2003 | 01:25 PM
pks485's Avatar
Mirror
Do you know how this could have happened. I don't recall ever hitting this mirror.
Thanks.
Old Jun 30, 2003 | 06:25 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
well, the motor may have failed, somebody might have wacked it in a parking lot, water may have corroded the plug, plug may have become somwhow disconnected......
btw did you check the fuse?
only way to know is to carefully take it out, open it up and see.....
